U Can Do 3D
You are correct Coomarlin, the rudder and elevator do travel more than the ailerons. My rudder and elevator both travel 50 degrees but I had to cut the corner off one elevator half since at maximum down it hit the rudder pushrod.
50 degrees down elevator and 70% spoileron (down with down mix) make for incredible waterfalls and KE Spins.
