RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-17-2003 | 01:58 PM
  #997
coomarlin's Avatar
coomarlin
Default U Can Do 3D
I'm thinking of trying to cut a hatch using the following method. I need some contructive critizism.
I've attatched a diagram of what I was thinking. I'm was thinking about using epoxy to attatch the small trianglular pices to the corner of the fuse cut out and I intended to use small screws to attach the hatch to the plane. Do you think this would be strong enough to hold the battery in place?
Also, do you think this would even be worth while, or should I just add lead to the tail. I need to get the CG back about 1/2 inch so I'm not sure how much lead that would take. I'd like to keep the weight as low as possible.
The reason I elevated the battery was in order to get a zip tie to go around it.
Comments?
