RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-17-2003 | 03:20 PM
  #1002
George E.'s Avatar
George E.
My Feedback: (16)
Default U Can Do 3D
I mounted my battery in the UCD the following way:
1) I cut a large hole in the balsa sheeting on the fuse bottom, almost the whole width of the fuse and maybe 4 inches long just ahead of the bulkhead in the middle of the fuse.
2) Snip the battery wire and solder in a 12" or so extension.
3) With the plane inverted drop the battery in the hole so it rests on the top of the fuse and is against the bulkhead. CA a piece of balsa sheeting to trap it to the top of the fuse. CA a balsa stick to stop it from sliding forward.
4) CA the sheeting back on the fuse bottom
5) Cover with monokote trim sheet or monokote.
Took about 30 min. I have no access to the battery but I don't need it. I mount most batteries in the back of the fuse, saves tons of lead.
Just another option.
