RE: centering aileron electronically
Turn your radio on and check the position of the servo arms. They should be 90 degrees to the servo. If not, unscrew then, pull and try to get them centered. After you get them as close as possible with the splines on the shaft. go to the subtrim function on your radio and center the arm exactly. You should have the trim centered to do this.
