RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-23-2003 | 04:51 PM
  #1043
Fixed Wing's Avatar
Fixed Wing
Default U Can Do 3D
Nosram,
Flew my UCD quite a bit on Tuesday. My CG is right at 6". My Elevators are fine like yours until I transition into a Harrier then everything goes bad. I have tried doing this 2 ways. First, by raising the ailerons to a fixed position of about 80% up before I start the Elevator with no coupling to the elevator servo and then increasing the elevator stick. Second, by mixing the ailerons to raise to 80% as a slave to elevator stick up movement. Both ways got similar results with the mixing method being a little more dramatic. Funny thing I noticed tho is that when I fly slow, straight, and level and then go into a Harrier it will do fine until I have to use the rudder. I have elevators and ailerons permanently mixed to rudder movement for knife edge, flat turns, etc. I wonder if this is whats causing me to loose it out of and Elevator as opposed to entering straight, slow, and calm? I'm sure I am subconsciously using the rudder when I try to transition from Elevator to Harrier and maybe this is screwing things up because of the coupling involved? Is yours set up the same way? Maybe I should put my rudder mixes on a switch rather than have them permanently active?
