RE: Engine history lessons
Jens, the way you see my engine is exactly the way I received it, the box still has the original foam in it and your engine would never fit in the box you see in the picture. The plates on the crankcase appear to be factory made as are the gaskets. If yours has one way valves on both sides, it supercharges like a YS and must run about like a 1.20. Mine has surprising compression holding ability.
