RE: Stab Wing Incident Update
Jim While working on mine I noticed how short coupled the C130 is. Iam sure that will make it pitch sensitive as well as the CG sensitive, A little nose weight might help..
On mine I added 4 inches to the center section so I can run a bigger prop. I am using 52 four strokes on mine. I am just about to the sanding and finishing stage.
