Originally posted by seanychen
Saito 100 is okay. I have it in my UCD. Vibration is not bad at all. The vibration shakes the plane most at 1/4 to 1/3 throttle, after that the amplitude is not bad at all. I guess UCD's resonant frequency is about 2000 ~ 2500 (divide the 1/4 throttle rpm by 2 for 4-strokes).
The only thing that came loose was the landing gear and the former in front of the wing.This you really have to add triangular stocks.
Now, if you are thinking about a Saito 180, then it's a different story.
Hi seanychen, I am not concerned about the level of vibration after the engine has been broken in. I am concerned about the high "knocking" level of vibration during the break in. The arf firewall is glued on with hot glue ain't it ?
