RE: How do u Check the CG of a plane?
I had same problem with my Avistar when I upgraded to ST .40. I wound up moving the battery behind the radio compartment. I secured it with some double sided tape and a small piece of balsa, it was basically held under the control rod housings. I guess I should have cut a hatch and secured it with velcro, but it never moved and I'm lazy.
Andy
