RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 06-07-2003 | 11:43 AM
  #1178
=XGC= OzZ's Avatar
=XGC= OzZ
Default U Can Do 3D
Originally posted by Jack Lewis
I'm about to mount my Saito 100 in my UCD and noticed there is no built-in right thrust. Has anyone noticed if any right thrust is needed and how much?
The instruction manual notes that the center line is offset to the left side to accommodate for right thrust. There should also be 2 degrees of right thrust built into the firewall but on my model the thrust line was dead center and the firewall mounted square. To fix this I put 2 washers behind the motor mount on the left side and shifted visually the motor mount to allow the motor to exit through the center of the cowl. The pictures above show this in detail.
http://www.rcuniverse.com/reviews.ph...ew&reviewid=44
