RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 07-06-2003 | 02:21 AM
  #1219
cmitch232-DELETE
Default Saito 100/Cline pump?
Flew my UCD for the first time yesderday. I have a cline regulator on mine. Started with needle valve 5 turns out per instructions. I have been turning it in gradually. I'm now about two turns out. I have about half a gallon thru it and am wondering where most guys with the cline regulator/saito 100 wound up needle valve wise. Yes, I know that altitude/temperature/humidity will affect the setting, but I just wanted a ball-park place to start. So far, it's run almost the same, not gaining or losing rpm as I have turned the needle valve in. Will it start to lose rpm on a tach as it would without the regulator?
Keep 'em flyin'
cmitch232
