RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 07-06-2003 | 09:28 PM
  #1222
sloanfs's Avatar
sloanfs
Default U Can Do 3D
cmitch232
I have the 100 with a cline and while the needle is not as sensitive as before it adjusts the same way. Open the throttle lean it slowly till rpms drop slightly. then richen it up about 1/4 turn. that will get you close . after you get it right you wont need to touch it again , unless you goextreme to temperature or altitude changes. You'll love the combo
Dave
