RE: How do u Check the CG of a plane?
Unless I missed it, when you pick up the plane using your index fingers, get as close to the fuselage without touching it as you can. and you do it facing the front of the plane, placing your fingers under the wings
In your one post you mentioned the belly and that had me concerned.
