U Can Do 3D
Thanks for the warning basmntdweller. Reminds me to spray some clear lustercoat in the fuse. Did this happen to the stock tank ? Did you use any foam padding between the tank and fuse ? Funny that the rubber compression was not enough to prevent vib from loosening the screw.
