RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 07-29-2003 | 04:17 AM
  #1317
Volfy's Avatar
Volfy
My Feedback: (23)
Default U Can Do 3D
Originally posted by wink5360
...It flys great but the vertical stabizer have fallen off on a number of them in flight.
Wouldn't the first time be the clue to glue it back really, really good?
Compared to some ARFs I've had , the vertical stab mounting design is fairly robust. However, mine was severely cocked to one side dry-fitted. I had to tape and clamp real hard to the opposite side while the epoxy set to correct it.
I do agree that it builds a little tail heavy though. I have the servos, engine, tank and gears installed so far, and the CG is wayyyyy back there, probably 7~8" behind LE. Still, I'm sure I can shift the CG up to at least 6" once the cowl+prop+spinner+battery are added. From what you guys are saying, 6" should fly just fine.
