U Can Do 3D
Fellas,
I am having a blast with this plane. I just started experimenting with my Futaba Super 8 and what a difference. I used the PMIXs for KE flight compensation and also coupled the Ailerons to the Elevator (Ailevators) WOW!!!!!! My roll rate is unbelievable now when I flip the switch the UCANDO3D (hate the name) just spins around it's axis as fast as I want or as slow as I want. I am only powering this plane with a Magnum 91 Four Stroke with a 15x4W prop. I have unlimited vertical, pulls out of a hover slowly but that is good enough insurance for me. Plane is all stock and I have around 20-30 flights on it. CG is still forward around 4 7/8" to 5". I want to get into flat spins / blenders. Do I need to move my fuel tank from stock to center wing and move my CG back? What do you all recommend? I still want the plane to fly comfortably.
Jeff
