jett 60
What props, pipe, fuel & rpm were you running? Did you run the engine on a test stand before the flight? You must launch rich with the DD or you will lean the engine. Also, a Dust will turn so fast it will starve the engine of fuel, a bladder tank will help here or wider turns.
Mark M.
