RE: GP J3 Cub ARF Engine Mounting
Guys, if you mount the 4-stoke inverted, does the header/muffler protrude thru the side of the cowl? I downloaded the manual, and it shows a 4-stroke mounted @ 9 o'clock. UGH! I don't want to cut a hole in the cowl sides, only the bottom. I was thinking of using an O.S. .70. Thanks.
