Need some help with figuring out amp draw
Alright,
I got all my equipment purchased, the only problem being is the prop and possibly having to change gears. I asked for help at another unnamed forum, and basically got no help. I need to know a range of props to get so im not pulling to much amp from the battery/etc
Here is my setup and I appreciate all the responses ahead of time
gws 400c
D gearing
3s kokam 1500mah 8c discharge
pixie 20
I need to know what size prop (range) i should be using to make sure im pulling the proper amps from the combo. Also, should i change gears? I am purchasing a whattmeter so i can fine tune it, but i dont want to buy 20 diffrent kid if props to see what one will work =/
Again, thank you for the help ahead of time
Sean
