RE: Looking to the conversion nuts for help!
Ok, the original magneto ignition is being used.
The engine will run for about 1 second and then not sustain running. It is as if it runs out the prime. I have used two different carbs, thinking that the carb was not pumping, and both did the same thing.
Does this help?
Tom
