RCU Forums - View Single Post - Engine for Somethin Extra
Old 08-14-2002 | 02:46 PM
visioneer_one
My Feedback: (506)
Default tail Pics.
Originally posted by JT-Indiana
One more question, Visioneerone I noticed also that you used a Dubro tail bracket. I'm about to that point. I do know that you have to do some modifying to the Sullivan to get the guide wires to attach right. Did you have do do any mods to the Dubro to get it to work. Also did you run a wire up to the rudder or just tell it castor? Got a pic???. Thanks JT
No mods. The tailwheel is attached to the rudder in he conventional manner.
Personally I'd have gone with something similar to the Graphtech tailwheel brackets, as the piece that attaches to the fuse is completely flat. I could then just drill an extra hole to mount the tail struts.
(Pardon the dirt.)
Yes, the rudder is attached wrong. You should have seen the gaps in the control surfaces before I sealed them! Big enough to throw a dead cat through. Remember - this one was a gift, I didn't assemble it.
