RE: Radio Range Trouble.
make sure that your RX antenna and servo leads are as far away from your ECU and Fuel pump as you can get them! Are you using a whip antenna on your RX or is it stock? I had this problem even with the antenna outside of the plane and I put on a Revolution antenna and it fixed the problems.
