RE: bubbles in OS 50 sx
Bubbles in the fuel line between the needle and the carb on the O.S. Max .50 SX engine is not common. After you check for air leaks, please check to make sure you're not getting air agitated into the fuel tank by the enigne's vibrations. This makes micro-bubbles which collect at the needle until a large one breaks off. Then you see it.
