RE: Radio Range Trouble.
That about the 20 flight before the problem, is the main reason that drive me nuts.Nothing is change,and the problem occurred from one flight to the next.????.
I been thinking about the ferrite on this cable, but I been told that this not doing anything on a PCM receiver.But work perfectly well on a PPM receiver.
But I will try it out.
And yes I have try two types of whip antenna.
And its no EGT sensor running outside the turbine, its a manual start on this one.
I been looking all over after metall to metall that will make "noise"
Roy Jimmy
