Need help Identifying this airplane Kit
I picked up this at an estate auction at a fun fly we had this weekend, I need help identifying it.
Its length is 45 inches from front of cowl to tail.
Its wing span is 71" not counting balsa blocks for the tips, probably will be 73 to 74 inchs.
The fuselage is all fiberglass, including the canopy, it has metal landing gear mounted to the fuselage forward if the wing.
Also it has all fiberglass cowl and wheel pants.
The wing leading edge is straight and the trailing edge is tapered.
The wings are foam core sheeted balsa, they are cut to except two aileron servos.
I think that is all I can see about it for info.
Here are some pictures.
Weskel
