RE: First flight Comp-Arf 2.6 Yak!
Im calling bullcrap on the fly all day on 700mah unless all day means 1 flight. My 3W 70 uses up a 2000mah in 4 flights (5 if I push it). You have twice the plugs that I have. I would definately have to see it to believe it. The 1 battery setup I think will be fine but you had better use regulators. Ill tell you why, you are giving those 5945 one and a half more volts than they want. Yep a single 5945 will work when you cram more voltage in it. I would worry more about the servos than the reciever, but the reciever will have some problems too. Thats just what I think.
