ORIGINAL: 3D ONdaEDGE
Im calling bullcrap on the fly all day on 700mah unless all day means 1 flight. My 3W 70 uses up a 2000mah in 4 flights (5 if I push it). You have twice the plugs that I have. I would definately have to see it to believe it. The 1 battery setup I think will be fine but you had better use regulators. Ill tell you why, you are giving those 5945 one and a half more volts than they want. Yep a single 5945 will work when you cram more voltage in it. I would worry more about the servos than the reciever, but the reciever will have some problems too. Thats just what I think.
I flew (3) 18min flights yesterday. No charging in between, sounds like your ignition has a problem. I ran a 500mAh on my 3W75.
I was hoping to have some questions on the flying qualities, not to argue over setups. I've had 5 years with no problems with this system and I've been running the same 5945's and receiver since they came out new, so I don't think I'll change anything.
Here are some pics.
(post edited to add pic's)
