RE: First flight Comp-Arf 2.6 Yak!
Darrinc , sorry to bug you about the set up but this is the same as
I am doing in my 2.3 composite aircraft only on a zdz 80.
I was wondering why the use of two different types of batteries ?
li Ion @ 2200mAh for RX and then the li Po @ 700mAh for the IGN .
Why not make them both Li Po or has it something to do with
voltage and duration.
For what its worth this is the cleanest setup I have seen , well done.
Stuart D
P.S. if your working to hard you either dont know what your doing or you,ve got the wrong job
