RCU Forums - View Single Post - Break-away engine mount
Old 10-26-2004 | 11:08 AM
Test005's Avatar
Test005
Default RE: Break-away engine mount
I agree.
Go get a 'normal' glass filled nylon mount, drill holes all the way through it and fasten the engine with one of the following methods:
1. Bolt + lock nut (lock nut has a nylon rim and you should NOT use lochtite or any thread locking compond on them)
2. Bolt + 2 nuts, the second nut secures the first nut. (use threadlock compond on both nuts)
I use method number two and it works perfect!
[link=http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=engine+mount&FVPROFIL=++]Tower Hobbies engine mounts[/link]
