blohmvoss,
First, I cut and installed 3/4 sq. x 1/8 thick plywood horn mounting plates and imbeded them into the bottom of the Ailerons. Recoverd them with Ultracoat film, then I installed Robart #331 Super Ball Link horns and used the bolt-on clevises supplied with these horns on both the Robart horn AND the servo output arm. NO PLAY NOW.
For some reason the holes in the Nylon Aileron horns where sloppy when mated to the supplied clevises and the servo output arm which implies that the clevis pins where metric and smaller than lets say a DuBro 2-56 clevis.
All other surfaces where install with kit supplied components.
BR
Kerry S.
