RCU Forums - View Single Post - Obsolete the Pin Box!
Old 10-27-2004 | 09:52 AM
  #89
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Obsolete the Pin Box!
ORIGINAL: Phil Cole
Phase changes due to rapid manoeuvre-induced changes in the antenna orientation may be a problem.
Bingo.
Dave, this is the issue, not the doppler shift. If the antennas are not oriented correctly you will have massive signal fade, almost infinite, but for sure -20 to -40 dB.
If you fly around level, or close to it, and hold the handhelds antenna correctly, you might get by. So the maneuvers are the thing, not the speed.
Comments?
