RCU Forums - View Single Post - Need some help with figuring out amp draw
Old 10-28-2004 | 07:53 AM
Matt Kirsch's Avatar
Matt Kirsch
My Feedback: (21)
Default RE: Need some help with figuring out amp draw
You can punch up the numbers using PCalc at www.flydma.com. Keep in mind that it's only a simulation, and isn't 100% accurate. It's best for getting RELATIVE figures.
I was a bit worried that you were trying to run a 6V Speed 400 on a 3S LiPoly. That wouldn't work for long. A 7.2V Speed 400 will be okay, though.
To tell you the truth, I don't have the foggiest as to what prop to use on this one. What's the actual ratio for a D gearbox?
