RE: NT-16 Engine
i use model technics [ only fuel my model shop sells ] 25% with average oil content .
could u explain to me the after run procedure this is the first i ve heard of this. i dont use any.. is this bad and does this increase the wear on my engine .
could someone tell me about the temp nt 16 should run , i use the spit test and when i run my truck around high end needle 2.5 turns from close it still boils the spit off within 2 seconds if i run any leaner it seems to sluggish , i normally use my truck on road which means flat out on straights stop turn around hit the gas back up the way [ get air off kerbs ] is it the flat out on the straights thats causing my truck to run hot, its never cuts out due to overheating.
oh ya thanks for the info on marine piston ,sleeve you think more torque , is it possible to pull wheelies then with this mod.
thanks very much for info please get back to me with any new mods ,trick, tips
madmark.
