RCU Forums - View Single Post - Newbee needs engines 101
Old 10-28-2004 | 03:31 PM
jagnweiner
Default RE: Newbee needs engines 101
Ned-
You mentioned that you need to learn the break-in procedure, but you also said that the TTs are missing a few parts. I assume that you managed to combine enough parts to make one engine. If your engines are missing parts, have they been run before? If they have been used, they probably don't need to be broken in.
-Scott
