RE: Need some help with figuring out amp draw
Unfortunately, and I have Motocalc, the best way to find the "Best" prop is mostly trial and error. If you can tell me how many amps you want to draw I could tell you the best prop Motocalc says for that amperage.
But it appears a 9x6 prop pulls about 8.7 amps and seems to have the best balance of speed and thrust per Motocalc.
Hope this helps.
