RCU Forums - View Single Post - Good 1.20 sport/pattern kit?
Old 10-23-2002 | 08:35 PM
Uncle Milty
Default Balsa Nova
I recently bought a Morris Hobbies Balsa Nova 120 kit. When I open the box, I closed it up and took it back to the lhs. The die cut parts were die crunch. It was the most messed up kit I have ever seen. They did not have any quality control when that one was packaged. The Balsa Nove 120 that I was flying had a little mishap. Don`t put to much power on the front. I was flying with a Mokie 210, pulling a 20X10 prop. I was going to make a high speed pass over the field when The aileron flutter tore the right aileron off, and the left aileron flutter stripped the gears on the servo. I lost it. Luckily the plane went away from the flight line and crashed where no one got hurt. Its good advise to reinforce the bottom, and the bulkheads, and to put at least 6" of glass on the center section. It is a great flying plane, and one day I will have another one.
