installing the engine,mount too tight
Hi,
I'm putting together an ARF trainer, the firewall came pre drilled for the engine mount,the engine mount is a standard 2 piece nylon mount,i bolted it to the firewall and tried to fit the engine in (TT46 Pro) but it wont fit,the tow mounts are to close so the bottom of the engine wont go thru. I guess i can use some force to pry the mount open or maybe grind it a bit, but i wanted to ask for advice first.
TIA
Eran
