RE: installing the engine,mount too tight
I had the same problem when I switched from my LA46 to a Tower 46 in my LT40. I just use the Dremel to cut out a tiny amount from the inside of each of the mounts, and drilled new holes. It worked fine until I decided to return the plane to kit form!
Glen
