RE: Cloud Dancer 40 Plans
> is all of the lite ply called for in the plans required? <
The only reason Lite-Ply is found in kits is because it is cheaper for the kit maker than large sheets of balsa. Don't hesitate to make the fuse sides of balsa and then add (real) ply doublers to them. You will end up with lighter and stiffer sides.
