i always giggle at these type of remarks to posts... first off.. PRACTICE YOUR DRIVING SKILLS! then once you master and know what you stock truck can do.. upgrade accordingly. yes they all have there weaknesses.. but as told a million times before... if you hit anything that will not move and your truck is cruising.. your going to break.... So practice your skills on driving.. the handling of the truck.. minor jumps.. which can be controlled with the throttle or brake for proper landing.. and then mod it... even the best parts in the world will break if you have a "loose nut behind the wheel"
