RCU Forums - View Single Post - f-27 stryker
Thread: f-27 stryker
Old 10-30-2004 | 10:22 PM
Fisher's Avatar
Fisher
Default RE: f-27 stryker
rckid90
Once you have downloaded FMS and have it installed and running. You can go to
http://gunnerson.homestead.com/files/fms_models.htm
Find the Styker and download the appropriate zip file. If you have FMS version 8 then you can use any of the zip files. I have version 8 so I downloaded the alpha 8.zip. Now you should have a .zip file on your hard drive. Unzip it an put it in the models folder that was created with your FMS program. Now you can simply select it just like any other model.
Good Luck
