RCU Forums - View Single Post - Which Engine?
Old 10-30-2004 | 11:37 PM
Frost_'s Avatar
Frost_
Default RE: Which Engine?
After you take out the old piston/sleeve, pull the crank. Clean everything with niro spray and make sure the bearings are smooth from the front of the crank... If they are rough you need new ones. Lube all parts up LIGHTLY with after-run oil, even the new piston/sleeve and re-assemble. Follow breakin instructions.
