RCU Forums - View Single Post - Cowled Engine Cooling?
Old 12-19-2001 | 02:01 AM
Hircflyer's Avatar
Hircflyer
Default Cowled Engine Cooling?
You can also do as in full size applications, use cylinder head baffles. This will direct the incoming air through the fins rather than around them.
Brass shim stock works well for this. Use two pieces leaving an opening in the front and rear of the cylinder. You can attach with copper wire soldered to the baffles and twisted together then soldered.
