caution, us 60 totoled.
just thought you should all know,i destroyed my h9 us 60 yesterday, the reason why it went in was i lost my elivator control.doing a close inspection i found that the pull/pull fiber had worn through where i had run it through the outside eye of the servo arm on the elevator servo,just like the system the termagator used and showed pictures of back earlier in this post,the system i used for the pull/pull was a sullivan #521 pull/pull cable kit.the kevlar cable needs to be run through a rounded surface as in a metal eye bolt,somthing that will not wear on the fiber.i do not know whut the termagator used as a pull/pull cable but the sharp edge on the servo arm hole cut the kevlar cable on my 12th flight,lost the plane,destroyed the engine,and radio.just a warning i thought others should know about,i will get another stick,they are a lot of fun.arniebarn..
