RCU Forums - View Single Post - caution, us 60 totoled.
Old 08-19-2002 | 11:17 AM
TriadSport
Default Pull - Pull
Gerry you mentioned the fishing leader line as pull/pull material. Have you had any problem with it bothering reception? This past weekend I finished my Edge 540 in which I used the steel line as I have had problems with the Kevlar. I ran the antenna down underneath the plane and thankfully did a radio check. My reception distance was cut in half of what I am used to. Wound up having to run the antenna out the side of the fuse and along the wing, reception now normal
