ORIGINAL: brit
I have nearly completed my special and am using a 3W 60 standoffs were one inch and really no problems in mounting at all The only thing is that with DA you get a lot better service ,but then you should they are built here in the U.S.A I would recommend that you go by what you like and what will work best for your application if you buy based on price alone you will be unhappy at some point
Brit,
I will be putting a 3W 60 on either my Edge or 300L.
Did you use pull/pull or go with rudder servos in the tail?
How is it balancing?
Any info they you think is important?
