RE: Starting first twin
Well the wing frame is done. Turned out real good. Nice and straight and after a bit of careful sanding the leading and trailing edges are good.
Gonna stop here on the wing until the gear comes in so its not sheeted until after the gear is test fit and wheel wells are in. Anyone know if you can still get the pre-fab ones? Don't see em up here.
About the servo's I guess using 3 in each wing (aileron, flap and throttle) is the way to go. The flap one would have to be outboard of the nacelle I suppose? Anyone use only one servo for flaps in the centre of the wing and use plastic pushrods (nyrod) out to each flap?
Latest pic...........
