Thanks for all the good info. Both of you. I will have to look out for the dreaded voltage drop you guys were talking about. That is when you land quick. To be quite honest about it I was about worn out when I sit my bird down after the first two flights, probably 20-25min. each in duration. Like I said it was a maiden flight for the "Red 13" Fw 190. Sure is sweet flying though, everything I hoped it would be. I am ecstatic about the performance of the Kokam 3s and Outrunner motor. Now I need the P51 or the P47 with the same setup.
Thanks again,
Rex
