RCU Forums - View Single Post - Help removing CA from plastic canopy!!
Old 11-01-2004 | 08:40 PM
DavidR
Default RE: Help removing CA from plastic canopy!!
Wet sand the whole canopy with 600 grit, then clean it and spray it with a light coat of clear ( I use PPG 2021) wet sand again with 1500, then 2000, and 2500. Polish it out with rubbing compounds.
Alternately Micro Mark sells a set of polishing sandpaper that goes up to 12000 grit it works very well, the above method has just been easier for me in the past.
http://www.ares-server.com/Ares/Ares...oduct&ID=80939
