RCU Forums - View Single Post - I wana Break-in
Old 11-02-2004 | 11:48 PM
ohsogood
Default I wana Break-in
Hi everyone,.....no i don't wana break-into anyones house.....i wana break-in my new OS .46AX engine.....the manual goes on to say that i should run it only once on ground changing needle settings every 10 seconds from 2 and 4 cycle settings.....then start flying on rich setting for a few flights without any stress runs. Not too sure about this.....i used to think that it should be run a 3-4 tanks on the ground on a rich setting.
So thats what i did.....run 4 tanks of 10% fuel though it on a rich setting with a 10*7 prop.....had some trouble differentiating between 2 and 4 cycle sounds (newbie) .....so i run it at about 2 turns open needle.....lots of smoke and oil came out of the exaust.
Does this mean the engine is broken in.....is there some way of knowing that the engine is broken in .....do i need to do something more .....have i damaged the engine by not following the Manual .....seriously i can't differentiate between 2 and 4 cycle sound. Dying to get it in the air....plz help
Thanks in advance
Ken
